Showing results for tags 'plot styles'.
Hi, I've just started using AutoCAD and would need to print out my first piece of work. I'd like to create a new plot styles so that my layer colors don't print as displayed (i.e. I want my blue, red and white layers to print as black and my green layer to print as yellow). According to all tut...
- 6 replies
- plot styles
Slow AutoCAD when in Paperspace with PLOT STYLES turned ON
samanthaberzina posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hello I have noticed a similar pattern with quite a lot of drawings recently. I work a lot in Paperspace and quite a lot of my files have recently started lagging awfuly if I have 'Display Plot Styles' box ticked as part of my Page Setup. If I turn the Plot Styles off, it resumes back to no... -
Plotting with Color Book's Color to Monochrome or Grayscale
toxicsquall posted a topic in AutoCAD Drawing Management & Output
I'm trying to plot one of my drawings to grayscale or monochrome style, but my lines and 3d polylines are colored with a color from a color book. When I try to plot, it will plot with the real color, even if I chose the Monochrome or Grayscale plot style. What can I do? (╥﹏╥)- 5 replies
- plot style
- plot problem
If I use our stb to plot to our printer, the print looks right. If I plot it using “DWG To PDF.pc3” the lines are lighter. Any suggestions? I can switch to using ctb's instead.
- 4 replies
- plot style
- management
Okay, so according to the practice I have to do, I need my Plot Styles from normal to Monochrome. The problem is that each layer has their own plot style Color_7, Color_34 and so on... and apparently we cant change it. Does anybody have an idea of how to do so? Thank you AutoCAD 13
