Showing results for tags 'plot style'.
    • plot style ×
Found 12 results
  1. Hi everyone, I'm trying to write a code that will 1) set the current plot style to "BCR Plot Style.stb" 2) change all layer properties to plot style "Grayscale" I had this working at one point, but can't get it to work when I reopen, so it may just be a problem with how I'm loading the rou...
  2. I'm trying to plot one of my drawings to grayscale or monochrome style, but my lines and 3d polylines are colored with a color from a color book. When I try to plot, it will plot with the real color, even if I chose the Monochrome or Grayscale plot style. What can I do? (╥﹏╥)
  3. I was working in LT 2014, everything running just fine since we got this version. Then last night I went to plot to a pdf using "monochrome" like I always have, and now it says "monochrome.ctb (missing)". It's the weirdest thing since it worked literally 5 mins before hand. I went thru the autoc...
  4. Hello, I'm a newbie to the forum, but have been using CAD for quite some time. I usually plot drawings directly from model space since they don't have to be professional or have title blocks for my job. I guess I have gotten a little rusty at paper space and now I am having a color plotting issue...
  5. WPerciful
    STB issue
    If I use our stb to plot to our printer, the print looks right. If I plot it using “DWG To PDF.pc3” the lines are lighter. Any suggestions? I can switch to using ctb's instead.
  6. Hi, Ive been given a block to attach to my drawings (text with color) to as built drawings and print. However when print this is affected by the grey scale and plots with no color. Im scared to try messing about to much incase i make things worse. I see tutorials online on changing layers etc bu...
  7. Hi, I have been using AutoCAD windows for 15 years but recently purchased AutoCAD Lt 2013 for Mac. I am doing some contract work for a company who have their own plot style (ctb file) that I need to use. I can't work out how to insert it into the Mac version. Any assistance would be greatly appre...
  8. Hi, I need a lisp routine to change the plot style of blocks in my drawing to 'bylayer' rather than the selected plot styles that they have been put on when they were created (by others). I would really appreciate if anyone had a lisp routine that would do this easily as there are many blocks in...
  9. I've edited the plot style table in the past to do things such as change yellow to print black. I've also successfully used it to select monochrome to print B&W. Currently it's not working. I can select a different plot style, apply it and see it look correct in paperspace. However, when I previ...
  10. bobsy852
    Plot styles
    Hi everyone, I've been trying to edit the way some of our jobs print, we need them in black and white, with the exception of 4 colours. Using the plot styles manager I have managed to do this by turning all other colours to grayscale, while keeping the colours we want to print in colour assigned to...
  11. Hello everyone, I've just started working in a drawing that has some strange plotstyle happenings... I was emailed the drawing, and it is in metric, and I don't have any info from the person who created it.. When I go to edit the current plotstyle or to create a new one I am not able to change anyt...
  12. andrewjbarnett
    Plot Style Lists
    I'm not 100% confident this is where this post/question should go. Where I work we have a number of departments, and each of these departments has different plot styles. They are all stored in the one location of the network drive, and are occasionally updated by the CAD managers. Because I...
