Showing results for tags 'plot preview'.
    • plot preview ×
  1. I've edited the plot style table in the past to do things such as change yellow to print black. I've also successfully used it to select monochrome to print B&W. Currently it's not working. I can select a different plot style, apply it and see it look correct in paperspace. However, when I previ...
  2. I'm creating a new project drawing and have x-ref'd my base drawing onto the sheet to be plotted. I can see the base drawing thru the viewport while in layout, but once I try and preview my plot the drawing inside the viewport is not visible. that is, I can see the preview of my sheet border & tit...
