Showing results for tags 'pline command'.
    • pline command ×
  1. Hi, I have just started using autocad two weeks ago and I'm trying to make my first script file, a joined, closed polyline that is a rectangle. The code is below: _pline -15000,0 15000,0 15000,-1000 -15000,-1000 c (there is a space after the 'c' and a return after the line) When I run,...
  2. I have just started using Autocad 2010 (i know i know, its not the latest )... but anyways. I am facing this unique problem where i have a 3d solid object in the drawing, and when the first point in a pline command falls within the boundary of the 3d solid, autocad automatically assigns some of...
