Showing results for tags 'pipe network'.
Copy a pipe Network item from XREF to current Drawing as Polyline
RamboGT posted a topic in AutoLISP, Visual LISP & DCL
I'm trying to figure out how to write a LISP command where I can click on multiple pipe network pipes from an XREF, and it copies them into my current drawing on the current layer, changing the linetype to contiguous, color to ByLayer, and seta global width of 1. Current theory on how t... -
A simplified version of my problem: I have been adding new pipe sizes to an existing parts list. As I add a new part, it is automatically inserted at the bottom of the list. Is there a way to reorganize the parts list by something meaningful like part name, style, or ideally inside diameter? It appe...
- 2 replies
- pipe network
- parts list
Hello, I am giving a presentation of a rather extensive pipe network I created. It doesn't seem to matter if I walk, fly, drive through or orbit the model, all pipe to pipe connections look like two paper towel tubes stuck together at the center. The plan view is fine, with bends and such but no...
- 26 replies
- pipe network
- pipe connections
Hello, I have a large pipe network. All works well with one exception. I am trying to apply a render material to the pipes and it renders very poorly. I drew a cube and sphere next to the network at an appropriate size, applied the same material and the cube and sphere render great but the pipes...
- 4 replies
- pipes
- pipe network
Hello, I am trying to find a way to grip edit pipes in profile view. I can get the invert and crown grips to work fine but I need to find a way to grip the outside top of the pipe. I have a lot of pothole data and an offset profile clutters up the profile view. Any help or suggestions would be a...
- pipe network
- pipe grip
Hello, I spent a good amount of time making a structure in part builder over the weekend. The part works great but I can not figure out how to add it to the catalog on our network. All help and suggestions are appreciated. Thanks, Phil
- 2 replies
- pipe network
- part builder
Hello, I am short on time and looking for a fast fix. I have the following situation: 100+ pipe network All alignments are in place and named correctly and styles applied 80% of the pipes are the same size and type Does anyone know a way to make a pipe for each alignment named the same...
Data shortcut references object to dwg without my permission
Mark_CV3D posted a topic in Civil 3D & LDD
Hello! My problem is when working in this project that one of my files that doesnt contain any civil 3d entities references some of my pipe networks from another dwg without me having telling it to do so:ouch:. So I delete all the pipes thats comes in uninvited but the next time i open the dwg it...- 3 replies
- pipe network
- data shortcut
I'm using AutoCAD Civil 3D 2010. I'm new to pipe networks so bear with me. What I'm trying to do is create pipe network from objects. So I go to Pipe Network> Create Pipe Network from Object> then slect my object.... but what if I want multiple objects under the same network? If I call multi...
