Showing results for tags 'pen styles'. - AutoCAD Forums Jump to content
    • pen styles ×
  1. Hi I am currently using Autocad 2015 LT in as a freelance in someones office. We tend to hatch our building outlines in grey solid but when we print the grey comes out as purple. I've been inside the network settings and adjust all sensible options but unfortunately it is still coming out as...
  2. I was working in LT 2014, everything running just fine since we got this version. Then last night I went to plot to a pdf using "monochrome" like I always have, and now it says "monochrome.ctb (missing)". It's the weirdest thing since it worked literally 5 mins before hand. I went thru the autoc...
  3. Every time I open a new drawing, I have to re link the path for my pen styles (CTB) I have to go to OPTIONS, and re link the path manually every time under 'plot and publish log file information'. It re links to the wrong path by default and I have to change it. is there a way to fix this. it's aggr...
