Showing results for tags 'parameter linking'.
    • parameter linking ×
  1. Is it possibel to link all lengths to unit QTY in bom, and partlist, i know frame Generator is using G_L for length, i've tried using it in other parts but no result. also when doing multi body parts, how is it possibel to use parameter in assembly parts. i'm interrested in this because i d...
  2. I am having trouble getting the linking function to work between an Excel spread sheet file and Inventor 2012. I have set up the spread sheet file according to the tutorials I have read and attempted to link it to an Inventor model in the parameters dialog box but all I get is the name of the linked...
