Showing results for tags 'page setup'.
    • page setup ×
Found 6 results
  1. Hi all, I am having issues with what I believe could be a corrupted page setup file. I have gone to the page setup manager to try and delete and re-create, but ANY interaction with the page setup in question causes CAD to immediately lock up and crash (even a right click, somehow). Does anyone know...
  2. I have my pages set up for all the size drawings that I do but I want to change one thing in the properties of the plotter that I use. I want the lines to merge instead of override, after I set up that change it asks if I want to save the changes and I do. yet the next time I plot the plotter proper...
  3. Dear CAD specialists, is there a way to read information from drawing (e.g. content of a specific text object, content/value of specific attribute or any other object that I can place in a layout) and then put that information in a command string? LISP is not in the range of solutions as: 1...
  4. Dear all, Hopefully someone can help me. I have been using until saturday Windows Vista and Autocad 2008, with out any problem, at least that windows vista was slowly. So I decide to upgrade my notebook and I add windows 7 - 64 bit and change my autocad to a 2010 version for this windows 7 a...
  5. I have too many paper sizes in PageSetup. This makes choosing the proper page size too lengthy and time consuming. I only use two paper sizes namely A4 and A3 so I don't need to have English paper size like 11x14 in, Hagaki, Index Card and 30 other pagesetup. How can I del...
  6. Hi all I have this reoccurring issue with ACAD. It appears randomly and whenever we upgrade to newer versions of ACAD also. Now that we are upgrading to 2012 it has reared its ugly head again. Heres the issue; when I go to publish a set of drawings from sheet set manager it refuses to do so. It...
