Showing results for tags 'ole objects plotting'.
  1. squareknees
    Ole vs. Pdf
    I inserted the same object 2 different ways and I get 2 VERY different results. The first image is an Xreference of a PDF and this is how it turns out. the second image is when I copy the image from the PDF and paste it into AutoCAD. I got this PDF and it is really light and I need to take dimensions off of it. when I try to create a PDF the top image ends up lighter then seen here and the bottom image ends up black or white with no details at all. HELP! I have already spent too much time on this I just need it to print out dark enough to be able to read it!
