Showing results for tags 'offset error'.
    • offset error ×
  1. Why cannot I offset this shape 1.0 mm towards outside? I have attached the original dwg file here. Thank you very much! cannot offset.dwg
  2. Guys, Attached here I have one drawing with a pline exported from another software, I receive a lot of this kind of entity with the same error, someone know's how to fix it, or it's possible redraw it with another line but as the same format!... (Try to do a offset of 20 mm about that entity, t...
