Showing results for tags 'odd performance'.
  1. hey guys, been having some odd performance with my student version of 13. i've completely uninstalled and re downloaded it from autodesk with the sp and update 1, and it still does it. it would be a few things. first off, when i create a new part the ribbon stays grayed out for quite a bit, but seems to load a bit faster if i click it. when it finally comes to, it works and is ok in speed, but some icons seems to lag a bit when loading and flipping from tab to tab. the view cube no longer highlights the edges when you hover over them with your cursor. its performance is laggy it seems, i can still click the edges and it will eventually snap the view to them, but is not snappy like it used to be at all!! clicking in the tree is also laggy like this, it works, but is very slow in response. i have a 3d mouse, just updated all its drivers, and it still does it. i've gone through a couple updates on the graphics card (gtx 680), and it seems to have started since then. i don't think i launched inventor all that much since my last update on the card, and this has all started after that. i'm going to try and revert back a few updates and see if that helps, but that's why i'm posting this. if anyone has heard or seen of this type of thing, were you able to get it resolved? what did you do? any help is appreciated!! -thanks
