Showing results for tags 'obliquing angle'.
    • obliquing angle ×
  1. I have been working to correct issues we did not realize we had with PDF output from AutoCAD DWG and Inventor IDW files. I have seen several posts related to the same thing so I wanted to share what I have discovered and the fix for it to date. If you are finding that your DWG files or IDW file...
  2. I am drawing an isometric drawing. In order to draw a dimension line, the tutor says I have to change the obliquing angle to s0 for left plane and -30 for right plane. I could find anything in: Modify Dimension Style Where should I change this angle?
