Showing results for tags 'oblique angle'.
    • oblique angle ×
  1. I have been working to correct issues we did not realize we had with PDF output from AutoCAD DWG and Inventor IDW files. I have seen several posts related to the same thing so I wanted to share what I have discovered and the fix for it to date. If you are finding that your DWG files or IDW file...
  2. Do i need to create 2 styles, 1 with oblique of 30 and 1 with oblique of -30? Also can i put these on a tool palette? Thanks
