Showing results for tags 'object snap'.
    • object snap ×
Found 7 results
  1. Greetings, everyone. I've been using AutoCAD on and off for the last couple of years but unfortunately I seem to have missed out on learning what appears to be basic / common knowledge amongst the community. When I try searching for solutions to my issues they are always writ...
  2. Hello, I am working with a couple different drawings in AutoCAD 2007, and pasting items between them. For some reason, I am unable to use object snap on items that have been pasted into the main document from one specific file. I am able to use OSNAP on these items if they are pasted some where...
  3. I'm not sure why but my object snap turns itself on. This happens when new drawings load, between commands and when I go from drawing to drawing. It's the insertion snap that turns on. Also the grid snap turns itself off when new drawings load, between commands and when I go from drawing to dr...
  4. Is there a way to set a 'snap hierarchy' for example, I want the 'perpendicular' snap to snap before the 'nearest' since it's more accurate. I would rather 'nearest' be the last resort snap if nothing else. thanks,
  5. Hi, I was messing about with my CUI yesterday and found that there wasn't an icon for the Mid between 2 points object snap. I had a go at making one and thought I'd share it here for others to use. (right click and 'save picture as') I based it on existing icons and it's basically 2 poi...
  6. I want to divide a line to three equal parts and draw lines stating from divided points. Command "devide" neatly do the dividing job and put marks for points. Appearance of these makrsers could be altered by ddptype command to become more visible. However I can't snap to these points when I want...
  7. I'm using ACad MEP 2010 and attempting to change Object Snap settings via the Drafting Settings. When I select settings I get: Which seems corrupted. If I click on, say, Tangent I get: Can this be fixed? Thanks for your help.
