Showing results for tags 'noob in civil 3d'.
    • noob in civil 3d ×
  1. arlene
    Civil 3D Help Needed
    I am receiving error message "surfaces do not overlap" when i try to get volume between two surfaces.. i have two surfaces: 1. Made up of Survey points 2. Polyline which i put an elevation to make it 3d poly and then convert it into block before making it a surface. What could have I done wron...
