Showing results for tags 'nested block'.
    • nested block ×
Found 5 results
  1. Hello, I have this code I use to automatically annotate my details (FAS). It takes the block´s name and its description and inputs them into two attributes of the block I use to define a specific Multileader (Smart Multileader). I would like to make it work when selecting nested blocks....
  2. Is there a method to update blocks and nested blocks (dynamic and/or annotated without losing their position, visibility status, and annotated values: Tag/prompt/default values) based on new blocks that will contain in a folder (source files)? New blocks have the same block name as old ones. The cad...
  3. I found a lisp (attached) to change object line type. But this lisp is not changing nested blocks line types and forcing one by one selection . I need to change linetype of all objects include nested blocks and as area selection. Please help ChangeObjLinetype.lsp
  4. I have recently downloads a pile of files, blocks for inserting, symbols. Apparently all files have block in them of the same name of the file name. Thus, upon inserting a file I get the error "block reference itself" and will not insert. Is there a means of removing the block in the file in a...
  5. Hi everyone glad to be in this amazing forum. Straight to the point: is there a way to explode the nested blocks in a drawing that contain a a common word in their name? In our case we have a lot of blocks exported from vectorworks whose name was substitute with -group-xxx-y, is there a way to r...
