Showing results for tags 'nearest polyline'.
    • nearest polyline ×
  1. How can I find the nearest line which is parallel with the target entity. As in the image, I want to find the green line in both case, notice the red line has a smaller distance to my target "abcedfg", but in the second case, the parallel part of the polyline has a longer distance than t...
  2. Hi all, I'm trying write a LISP routine which will accomplish the following: 1. Select the block reference on the drawing 2. Find the closest polyline and closest point on that polyline from this block reference 3. Create vertex on that point and save the coordinates of this point into a vari...
