Showing results for tags 'named object'.
    • named object ×
  1. I use Dynamic Block and insert attribute field for value - placeholder - name. here is a print screen - http://joxi.ru/l2ZYpRXU88VExm If i attache the file from a reference in another file, this bloc shows the block name and file name in attribute value. view here - http://joxi.ru/zANBvYdfllwB...
  2. HEADACHE! I am trying to write a LISP that does the following: -Open drawing -Saveas as NEW drawing based on certain criteria from DCL menu -Deletes old drawing -*THEN, if drawing contain attached IMAGE FILE (.tiff in my case)... Rename image file and repath image file based on the new f...
  3. Hi all, is it possible to: 1- Get properties of a table group (such as a layer, textstyle, dimstyle, ...) 2- Save the information inside drawing (via Dictadd, etc.) 3- Purge the processed table group. So it will be possible to restore the information when needed. If possible, any s...
