Showing results for tags 'multiple files'.
Hey all, New to C# and trying to slowly get my way around. I can get a variation of my code to work with MDIActiveDocument but what I really want my program to do is allow the user to select a bunch of drawings and then perform some edits to them. I am just trying to get some text inside of an excel file inputted into the .dwg file. Here is my retag.cs file using Autodesk.AutoCAD.Runtime; using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.Threading.Tasks; [assembly: CommandClass(typeof(retag.Retag))] namespace retag { internal class Retag { [CommandMethod("DwgRetag")] public void DwgRetag() { // get the excel information ExcelHandler xlHandler = new ExcelHandler(); Dictionary<string, List<(string, string)>> tags = xlHandler.GetTagInfo(); // get the list of .dwgs dwgHandler dwgHandler = new dwgHandler(); List<string> dwgs = dwgHandler.GetListOfDwgs(); dwgHandler.AddTags(tags, dwgs); } } } here is the dwgHandler.cs file using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.Threading.Tasks; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.Geometry; using Autodesk.AutoCAD.Runtime; using System.Windows.Forms; using Application = Autodesk.AutoCAD.ApplicationServices.Application; using System.IO; using Exception = System.Exception; namespace retag { internal class dwgHandler { public dwgHandler() { } public List<string> GetListOfDwgs() { List<string> dwgFiles = new List<string>(); // Create an OpenFileDialog to select .dwg files OpenFileDialog openFileDialog = new OpenFileDialog { Filter = "DWG files (*.dwg)|*.dwg", Multiselect = true // Allow multiple file selection }; // Show the dialog and get the result DialogResult result = openFileDialog.ShowDialog(); if (result == DialogResult.OK) { // Add the selected file paths to the list foreach (string filePath in openFileDialog.FileNames) { dwgFiles.Add(filePath); } } return dwgFiles; } public void AddTags(Dictionary<string, List<(string, string)>> tags, List<string> dwgs) { string documentName; // the document name List<(string, string)> dwgTags; // drawing tags foreach (string filePath in dwgs) { dwg acDwg = new dwg(filePath); // get the tags per drawing documentName = Path.GetFileNameWithoutExtension(filePath).ToUpper(); if (tags.TryGetValue(documentName, out dwgTags)) { acDwg.addTags(dwgTags); acDwg.CloseAndSave(); } else { continue; } } } } } and the dwg.cs is: using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.Threading.Tasks; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.Colors; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.Geometry; using Autodesk.AutoCAD.Runtime; using Exception = System.Exception; namespace retag { internal class dwg { private Document doc; private Database acDb; private Editor ed; public dwg(string filePath) { doc = Application.DocumentManager.Open(filePath, false); acDb = doc.Database; ed = doc.Editor; } public void CloseAndSave() { try { // Save the current document doc.Database.SaveAs(doc.Name, true, Autodesk.AutoCAD.DatabaseServices.DwgVersion.Current, doc.Database.SecurityParameters); Console.WriteLine("Document saved successfully."); // Close the document doc.CloseAndDiscard(); Console.WriteLine("Document closed."); } catch (System.Exception ex) { Console.WriteLine($"Error saving or closing the document: {ex.Message}"); // Handle the exception (log, display, etc.) } } public void addTags(List<(string, string)> tags) { // Define the starting coordinates double x = -10.0; double y = 21.0; double verticalGap = 0.2; // Create a new layer for the first tag in each pair string layerName = "old tags"; CreateLayer(layerName); // Iterate through the list of tag pairs foreach (var tagPair in tags) { // Create the first text object (tag1) on the specified layer CreateText(tagPair.Item1, x, y, layerName, addBrackets: true); // Create the second text object (tag2) next to the first one CreateText(tagPair.Item2, x + 1.0, y, "0", addBrackets: false); // Assuming "0" layer for tag2 // Move to the next row y -= verticalGap; } } private ObjectId CreateLayer(string layerName) { using (Transaction tr = this.acDb.TransactionManager.StartTransaction()) { try { LayerTable layerTable = (LayerTable)tr.GetObject(acDb.LayerTableId, OpenMode.ForWrite); if (!layerTable.Has(layerName)) { // Create a new layer if it doesn't exist using (LayerTableRecord newLayer = new LayerTableRecord()) { newLayer.Name = layerName; newLayer.Color = Color.FromColorIndex(ColorMethod.ByAci, 3); // Set color to green ObjectId newLayerId = layerTable.Add(newLayer); tr.AddNewlyCreatedDBObject(newLayer, true); // Commit the transaction tr.Commit(); return newLayerId; } } else { // Layer already exists, return its ObjectId return layerTable[layerName]; } } catch (Exception ex) { // Handle exceptions (log, display, etc.) Console.WriteLine($"Error creating layer: {ex.Message}"); return ObjectId.Null; } } } private void CreateText(string text, double x, double y, string layerName, bool addBrackets) { if (this.doc == null) { // Handle the case where there is no active document return; } using (Transaction tr = this.acDb.TransactionManager.StartTransaction()) { try { BlockTable bt = (BlockTable)tr.GetObject(acDb.BlockTableId, OpenMode.ForRead); BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite); // Add brackets if requested if (addBrackets) text = $"({text})"; DBText textEntity = new DBText { TextString = text, Position = new Point3d(x, y, 0), Layer = layerName }; btr.AppendEntity(textEntity); tr.AddNewlyCreatedDBObject(textEntity, true); // Commit the transaction tr.Commit(); } catch (Exception ex) { // Handle exceptions (log, display, etc.) Console.WriteLine($"Error creating text: {ex.Message}"); } } } } } the main issue i am currently running into is that when it closes and saves, I get an error from autocad saying "error closing/writing file" and in my debug window I am getting "Exception thrown: 'Autodesk.AutoCAD.Runtime.Exception' in Acdbmgd.dll" and I cannot for the life of me figure out why this is happening. My google-fu comes up with stuff that I am confident I am not doing. Any and all help is appreciated.
Let’s say you have DWG title block template file, “DAY” with attributes tagged, “B” and “C”. You also have XLSX file, “CAL” with column A rows, (1 thru 7), column B rows, (ONE thru SEV) and column C rows, (SUN thru SAT). How do you use any programing method to create 7 drawings automatically using the template and the worksheet, numbered sequentially so that file “6.dwg” would contain title block displaying “SIX” and “FRI”? Thank You in advance. If I may be any more specific, please ask.
- 2 replies
- excel attributes
- automatically
