Showing results for tags 'multi leader'.
    • multi leader ×
  1. Hello, Does anyone know how can i set to default Not to have Multi leader text sitting on the line ? i want to be able to set it in the Multi leader setting window, i want to keep it the same each time. see issue on pic. thank you. Note Autocad 2017
