Showing results for tags 'mtext formatting'.
    • mtext formatting ×
  1. Hi, I found OneMtext.lsp and Text2MTextV2-0.lsp which are both very useful for my needs, but I wish that the contents could be set to sort by alphabetical order. Can anybody help me or point me in the direction of how to modify the lisp so I can have this result? Thank you OneMtext.lsp Text2...
  2. <Update:> The issue I encountered was a drawing converted from VISIO to Autocad. If I convert the fonts to ARIAL beforehand, I can use STRIPMTEXT if not I have to use one of the methods below. I have several drawings filled with MText objects. If I select them...
