Showing results for tags 'moving block'.
    • moving block ×
  1. Hi, I have a problem that I have many drawings which contain number of the same block which should be hide. Based on tips from another threads I came up the following solution which I don't know how to utilize. First -> I use lisp which create new layer, then blocks with the same name are m...
