Showing results for tags 'move attributes'.
    • move attributes ×
  1. Moving Attributes in a Dynamic Block I have a dynamic block with 5 display states. In 4 of the display states I need my attributes to be in different locations. I have shown the approximate location for each display state shown in a dark red color. I do not know how to mo...
  2. The lines are pointing to the insertion point of the blocks (4 different ones) I want to replace these blocks with this block The line points to the insertion point (Center) After a Replace Block command for each block this is the result I made...
