Showing results for tags 'missing layers'.
    • missing layers ×
  1. Hi, I try to plot my drawings in this new template that i created - with all those new layer. I have compared it with my other drawings, the layer properties is pretty much the same however for this drawing, some of my layer are not visible in the viewport and missing when i plot the view. A...
  2. Hello CADers! Today I have came upon this problem: I'm trying to export my drawing into PDF, but when I press on the preview, I see that most of the drawing is not represented. the layers are not frozen or turned off. any ideas? also, it looks like i somehow screwed up my mo...
  3. Ok, CAD gurus. Put on your thinking caps because this one is a bundle of fun. FYI, I am using AutoCAD LT 2012. For your reference: Drawing 1.dwg Drawing 2.dwg The Scene of the Crime: I open Drawing 1 model space and copy some objects to Drawing 2 model space. Typically the layer pr...
