Showing results for tags 'mesh to solid'.
    • mesh to solid ×
  1. pizarro
    Mesh to solid
    Helo, I have many mesh and need convert to solid 3D, the adjunt is a example. Any lisp, visual lisp for this. thank you. MESH TO SOLID.dwg
  2. hello everyone, i have a project that needs to get the volume of the certain of the hull of a boat. from 2D i use align command to get the 3D form of the hull. then i to get the shape/surface i use loft command. i am doing it right? but from the moment i tried to get the volume using massprop comman...
