Question:
Is it possible to Map Material in the Block?
Why do I want that? Just made one block of stair, and copied them that I could do changes to all of them by one modify.
I want to fix the wood material map in that Block
EDIT:
Found a way how to rotate material, by rotating object by 90, add material again, and rotate 90 it back
I wonder is it possible to bypass those blocked command in Block?
