Showing results for tags 'map 3d'.
Hi, I am going through our company Lisp library to clean things up and rework old lisp's (as far as I can fix them with my basic knowledge of lisp's). For the following I have reworked the following HATCH Lisp How the routine looked before I got to rework on it:...
- 4 replies
- transparency
- lisp
Automate to create bounding box for all text objects
ernstloeffel posted a topic in AutoLISP, Visual LISP & DCL
Hi all, I'm new to both AutoCad (actually Map 3D) and AutoLisp. I need to create a plugin which creates the bounding boxes for all text objects, and write these bounding boxes to a layer named after a specific scheme, like OriginalLayerName_BoundingBox. So for an example, when a text object is o... -
Unable to view Object Data Table in separate window
whiskeyportal posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi, I'm attaching data to objects (adeattachdata) and I'm unable to get the table option to open in a new window. I tried fieldia and the value is already set to 1. I'm using Map 3D 2012 if that helps.- 1 reply
- map 3d
- adeattachdata
Hi, I have some drawings, where i see tables object data tables. After clicking map->object data->define object data I see several tables created with interesting fields, which may contain useful information. However as I am not familiar with Acad map I can't view this data. Can anybody tell...
- 3 replies
- map 3d
- data tables
I have received one (1) large SHP file that has all of the individual municipal/village boundaries for a larger city. I guess the same question would apply to isolating certain rivers or streams from a SHP file that contains all in the state. Is there any way I can extract or change these shape are...
Set Map 3D back to default
alster5356 posted a topic in The CUI, Hatches, Linetypes, Scripts & Macros
hey guys, I have map 3d 2010. when i was trained on this software i used the default ribbon based work space. our boss had someone come in to the office and standardize everyones workspace, which is great, as long as i'm just doing drafting. the new way it is set up is similar to AutoCad clas... -
Hello, I'm using Map 3d 2012 and trying to insert a shortcut icon(panel) into the INSERT tab on the UI Ribbon for the _MAPIMPORT function. I can't find the function in the list of commands, but the function is available if I type it into the command bar. Can anybody point me in the right direc...
Hi, im working on a project for university and it involves using .shp files, which i've imported fine, however the problem is that when i draw a line or polyline then save the file, close the program, reopen the file, the polyline appears for a split second while opening but then it disappears once...
- 1 reply
- shape file
- polyline
Does anyone know where i can get help in figuring out all the details and how to use AutoCad Map 3D? I understand for the most part all of the basics for regular AutoCad, but there is alot of stuff that is very different in this version that i have no idea how to use. Tutorials or anything?
