Showing results for tags 'map 2014'.
    • map 2014 ×
  1. This was working in Map 3D 2013... Basically, what I want to do is: open a dxf file copy it's database to a new dwg file close the dxf I modified the code a little bit to try and make it work with Map 2014, but without success. Here is my code now: // Open dxf DocumentDoc...
  2. I am migrating from Autocad Map 2009 in windows XP (32 bits), to Map 2014 64bits, in Windows 7 64 bits My question is if is possible to use visual basic 6.0 activex with Map 2014 64bits And if it is possible, what to do to get the interface to it. I have from history a "dll Visual Basic 6.0 A...
