Showing results for tags 'lsp file'.
    • lsp file ×
  1. Hello. I am using an old acad.lsp file with custom modified commands. After years of using it without any problems, it suddenly stopped working. This happened on two different computers with different versions of autocad (17 and 18) and without any software or windows updates. Au...
  2. Hi! I have this code that i found here in the forum it was created by @rlx. My question is how to add an automatic current date and time to the end of the file when im saving it. Many thanks! xoxo (defun c:foo (/ _dir F NF P SF SH) (defun _dir (msg path / sh folder...
  3. Hi, I'm having a hard time figuring out how to make a toolbar that can be downloaded for all to use. My problem is how do you share a "common directory" with the world? The toolbar works perfectly fine on my computer, because I have defined my own directory in the macro under the cui co...
