Showing results for tags 'lookup table'.
    • lookup table ×
  1. I have created a dynamic block for CMU, and it works great except for one thing. Please see image below, and the attached dwg file containing the block. Goal: Remove the 'Custom' option from the Lookup drop-down. Thank you for your time, in advance! CMU_8IN.dwg
  2. I'm trying to make a block with an item list where I can choose any or all of 10 line items, I can put a stretch and array to size up the list to exclude blank lines but I cannot figure out which method to use to make a checklist. Layers are not an option because our clients have certain layer lists...
  3. OK Guys, I've been searching endlessly for a solution to this, and I just can't seem to get anything to work. I'm writing a lisp that adds a line of revision text to our title block. We have about 6 different sizes of it. We use a dynamic block for the title block text that uses a lookup table t...
