Showing results for tags 'locked objects'.
Change colors viewport automatically after using lisp
Sandervp posted a topic in AutoLISP, Visual LISP & DCL
Hello everybody! I have a lisp file which creates 2 new commands. If I use tne first command, all the viewports in my drawing are locked. If I use the other command, they are all unlocked again. If I use these commands, also the colors of these viewports are changing. If I lock them, they be...- 4 replies
- viewport layout
- unlocked
Can't edit, delete, or move objects in a drawing
awhood posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hello, I am new to AutoCAD this year, just started an internship for the summer that uses it heavily. I am using AutoCAD P&ID 2015 while the drawings I am receiving are from a user who has 2007 or 2010 classic (NOT P&ID). The problem I am having is almost exactly the same as this post: http://ww...- 6 replies
- can't edit
- can't delete
