Showing results for tags 'lisp routine'.
Hello everyone I was wondering if there is a way or a lisp command that reduces vertices of curved polylines. When i say a "curved polyline" i mean a polyline that has two segments that are arcs with the same radius, and if i explode that polyline and join it again, those two or more segments/...
- 12 replies
- lisp routine
- curved polyline
Hello. I am using an old acad.lsp file with custom modified commands. After years of using it without any problems, it suddenly stopped working. This happened on two different computers with different versions of autocad (17 and 18) and without any software or windows updates. Au...
civil 3d Is there a lisp routine to move text to block base point?
CADman123 posted a topic in AutoLISP, Visual LISP & DCL
I want to move text to the nearest block intersection point so i can build 3d models from text. Without this my text is not bang on the marker.- 2 replies
- cad
- setting out
Assistance updating Lisp routine for Field Insertion
Billy Ray posted a topic in AutoLISP, Visual LISP & DCL
Hello, I have a lengthy lisp routine that hasn't been updated in years. It is strictly for Custom Field Insertions and I do not remember how to edit it. I created a diesel expression for what I'm trying to do which is simply adding dashes to a filename and removing the last 4 characters for ou... -
Lisp to display bearing and distance between two points
surveyscad2018 posted a topic in AutoLISP, Visual LISP & DCL
Hi I have written a Lisp routine (shown below) that measures the distance between two points, and applies a scale factor that is written within the lisp, and displays it within the command line. Although the lisp functions, it may not be the 'cleanest'. I was wondering if it was possible to a...
