Showing results for tags 'lisp polylines help'.
Hello. I work in the precast concrete industry and I am looking for a simple lisp routine to shave some time off our rebar drawing process. Right now we use poly lines to draw in the rebar. From there we have to list every single line to get its length, plug these lengths and Qty's into an excel sheet, then import a table into the drawings. There has to be a lisp routine that can extract length and qty's of all poly lines and put this info into a table right? From there, we can take it a step further, put the different lines on layers by size, and pull this info into the table as well. Anyone have any ideas?
Lisp for drawing poliyline with 3 inputs and a close
V-SAM posted a topic in AutoLISP, Visual LISP & DCL
HELP !! I am looking for a quick way to key-in 3 dimensions and then have a rectangle polyline drawn and closed. It could automatically start drawing at 0,0,0 The three user entries would be A, B, C where A and C would be different and the program would close the object. See attached for a better explanation. I appreciate any input on this.. I am not very good at writing lisps but i have good visions THanks guys you are the best. Document1.pdf
