Showing results for tags 'lisp lsp'.
    • lisp lsp ×
  1. I Have lisp for placing slope and arrow with polyline and i want enhance this to what i need mention in my drawing file..so i have attached lisp & sample drawing file . and also want to enhance lisp for select all polyline at once, currently lisp select on object at once. thanks....
  2. MCOLLAR.LSPMCOLLAR.DCL Collar Drawing.dwg Hey Guys yet with another question: I created this DCL that has 5 user input and I would like it to draw this complicated collar for me. Basically, the size of the mast (monopole diameter) is given together with the thickness of the collar plat...
  3. Sambuddy
    PDF
    I had a problem in the past whereby the first page appeared blank and I pulled out my hair to fix it - now that this problem is over I am back to yet give it another try to see if I can make this routine successful. Upon entering "PUB" command I would have three options (1st one uses autopub) (secon...
  4. (robocopy sourcepath destinpath "*.*" "/MIR") (if (newer-p flstxt1 flstxt2) (progn (c:robocopy-T2C) (prompt "******<<< Files are being updated >>>******") (princ) );end_progn if true (progn (prompt "---* No action taken. Files are already up to date! *---") (princ) );...
  5. I am trying to include every dwg extenstion in a list, only then to use for each to set them to read-only. (defun Read_only ( file / fso f ) (setq fso (vlax-create-object "Scripting.FileSystemObject")) (if (not (zerop (vlax-invoke fso 'FileExists file))) (progn (setq f (vlax-invoke fso 'GetFile...
  6. @Lee Mac hopefully you can answer me in your earliest convenience as almost everyone is moving from offices to homes, I am trying to find a way to update PCs. Basically, the overwrite function does not seem to work for me - if I make an update, I am trying to have to so that it updates the...
  7. Hey guys, I wrote a routine that automatically change the setting or copy files from server onto C drive. What I am looking for is an idea to invoke these changes each time I make any changes on the source folder. I do not want to search for changes, but rather I was thinking let's say acaddoc...
  8. Hey Guys, I am trying to write a lisp that has 4 or 5 list boxes. "LS1" would be the main list that appears on the first pane. When you click on "General" then second list box then would contain "LS2" as a sub category on the second pane. Then, if for example "LDF" from the second list/ pane is...
  9. hey guys, I am hoping someone can tell me what is wrong with my cad. I have been fiddling around with the autopublish to generate PDF and it seems somehow a variable or something was made incorrect. As a result, each time I publish say PDF or hard copy, first page/ tab of any project appears bl...
  10. The lisp below is lee macs Parsing numerical values from a text. I am wondering how to use this to change the colour within the selected Mtext only for real numbers that accompany "m", for example: 112.35m etc... <number> <dot> <number><m> sometimes there is one space between the real numb...
  11. hey Guys, I am hoping someone can let me know what is incorrect about my approach here. I have created 2 routines: IMP-CUI: which renames the old "acad.cuix" and bring in my updated one (do not ask why I did not use "vl-file-copy" method as the result was not satisfactory for me anyways)....
  12. Does anyone know where the file is saved each time you load the "LIST" that you saved on this amazing LISP? http://www.lee-mac.com/bfind.html The reason I am asking is because I would like to transfer my list onto another computer but I cannot find where the file is located when you save y...
  13. Would anyone help me find and change certain setting I would like to change under Options or preferences: 1) I would like to load and unload a buck of CUIX files - but as always the menu will not show up - I have to then manually do CUILOAD and unload and reload the menus to appear on me...
  14. Below is BIGAL`s wonder from 2011. All of which are amazing and never knew could be done! Imagine a 2020 BIGAL!!! Basically what I was trying to accomplish was to setup or configure my computer to then save the setting for any other but some tasks are proven impossible or not done effici...
  15. Could someone let me know how to use put-string to arrange text by colour so that example: all content in colour #2 remain but contents in colour # 0 and #4 are removed without changing any of the text format or style? I looked up Wmatch but it seems I cannot get anywhere with that. (setq t...
  16. I am trying to retrieve the current dimension style on an open cad file to execute some of my other lisps instead of (Alert blah...), but am not successful. Could someone take a quick look at this and let me know where I am getting it wrong? i had a quick look at tblnext and tblsearch and I thi...
  17. I am not even sure how to pose this question - so here she goes: I am not quite sure if you can select content with different colours within a text (see attachment). The code below only finds text colour selected by the layer. Is there a way? My whole intention is to sort them so that...
  18. I am trying to make this work but sometimes it works and sometimes does not. Please bare in mind that I just learned POLAR function and it may not the efficient way. The radius through fillet I am choosing sometimes works but sometimes comes up with an error that radius is too big. Is...
  19. Hey guys, I am trying to create a label (see attached dwg) using lisp to; upon entering the command: 1) ask for prefix then keep this prefix in memory (in this case BM-SC- let's say) 2) I would just enter the number associated with any block until i change my prefix 3) creat...
  20. Could someone guide me through this challenge: I am trying to create a lisp to have sub commands (I am not even sure what you would call it) - and when I search sub command I get a bunch of none sense. My first list is: [Bolt/U-bolt/Pipe/Angle/Plate/Hss-square] then un...
  21. What I am trying to accomplish would be two selection types: 1) what the default texts would be + a manual option and 2) where on the dimension the override to happen. I seem not to be able to successfully select one of the options under (initget "(Typ.) (TYpe.) (Plus-minus ±) Manual"): the ma...
  22. how do I get the first part to work? how do I combine the two? How do I have it so first pline is drawn/executed, followed by then (c2 command) measure command to insert specific block and then (c3 command) which is offset on both sides and delete original is executed? as you...
  23. Could someone take a look at this lisp and let me know how I can get true north based on the North Symbol attached to remember my last pick so I can enter values as angle once the true north is set - I am thinking something like Offset command that keeps last entry if it is at all possible. Attached...
  24. I did use STEAL lisp by MAC LEE before but since I am not inserting blocks anymore (Thousands of blocks on master general blocks), also because STEAL mess up the draw order on the hatch in dynamic blocks, is there a way: Upon entering a command to copy a selection coordinates from the source fi...
  25. I have seen so many lisps to change the draw order or send hatch to back, but would there be a way to: My dynamic blocks are on layers 0 and defpoint; 1) upon inserting a dynamic block 2) preserve the block draw order or 3) send wipeout at the very back 4) Defpoint la...
