Showing results for tags 'lisp error'.
Lisp that was running stopped
nargothrond posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Good morning, how are you? I have a problem with a lisp that I was using since 2011. Until last week it was working normally, but this week lisp keeps returning this error: ** Error: no function definition: nil **. My autocad is 2016, it's on a laptop with windows 10. I tried some s... -
Dear Masters, what is the wrong in my lisp program.please find error message while using the code. kindly fix the error. ;___________________________________________________________________________________________________________ ; ; Function to export a the coordinates of a group of poin...
Differences in Dimention and Coordinate points
pvsvprasad posted a topic in AutoLISP, Visual LISP & DCL
Dear Masters, i have one lisp for exporting points. and i have cross checked in excel values differences and auto cad dimension.i observed many points with 0.01m differences. for example in auto cad drawing showing 1.71m, but by excel coordinate difference is 1.72. why it is showing 0.01m diffe... -
Hello, I am new in coding lisp files. I worked with vb.net so this is very strange for me at this moment . I want to to select two points with different coordinates and to calculate difference between Z. I want to label that difference and to draw line with specific length under text. I did some...
- 15 replies
- length
- help with lisp
Hi, I have started to write a routine and it models what I wanted so far, except the last entity set to "HdrFtr". When I try to list data on "HdrFtr" I get this ... h *1410(1 |") (1 . "/061+ {rn rn {rn mhjqggjgoglifmkii rmmfqiimmfmokolgjjj nqj |") (1 . "/061+ {rn rn {rn mhjqggjgogligjmghl rmmiq...
- lisp error
- entity error
Hello. I hope you guys can help with my LISP. I am new to this, so forgive me if I sound too basic. A problem occurred all of a sudden, and it was working before. Now, when I open a dwg, it stalls at this portion of my acad file. That is how I narrowed it down to this particular LISP....
- 10 replies
- lisp error
- lisp
[LISP] First time writing LISP routine... trying to rotate, move and scale
chiimayred posted a topic in AutoLISP, Visual LISP & DCL
Hi guys, Total newb here, did some reading in the tutorials area in how to write lisps and I'm having issues with it not working. I'm trying to start off really simple hence the rotate, move and scale. This is my first time trying to program so please bear with me. Here is the code: (d... -
I'm hoping someone can help out with this one. I have a LISP that opens a DCL and prompts for user input, then sets the USERI2 variable. If I comment out the "if" function, the DCL works, and the USERI2 is set correctly. As soon as I put the IF back in, I get a "Bad Function" error that I cant seem...
Lisp Error (Can't find file in search path)
Alexico posted a topic in AutoCAD Bugs, Error Messages & Quirks
Hello. I have recently formated my pc , and i re install my Autocad 2011 version x86 and i loaded my personal Cuix. I have noticed that several lisps (block especialy , and scale lisps) are not working. When i try to add them in my files i receive an error , and a returning message , saying th... -
hi everyone just joined in and was wondering if any one with a good knowledge of lisp can go through the routine below which by the way is to generate an I beam with inputs from user and is not working. It does accept the inputs but nothing is drawn in the model space when i run it. Ill be much app...
_$ (PUTPAGESETUP "101" "PDF LEDGER") ; error: no function definition: VLAX-GET-ACAD-OBJECT I found the following code which reads named page setups ans supposedly is able to set it up, but when finally manage to get it to run, it seems to have an error somewhere. ; Jason Piercey . May 1...
I have ACAD2010 & am attempting to use a LISP routine that inserts a block for a photo callout symbol & the text for the photo number. The file contains a command "SAVSET" which I can't find information for it's purpose or it's syntax. When I enter the command, I get an error at the command...
