Showing results for tags 'line thickness'.
    • line thickness ×
Found 5 results
  1. AutoCAD - Format Menu - Lineweight Settings How to add or edit to create a new Lineweight
  2. Hello All, I've seen many posts about this issue and they seem to be resolved easily, but these solutions seem to not apply to my issue. My lineweights are not displaying properly in MS. I have set the layers' lineweights to 0 mm in Layer Properties Manager. I have turned on the Show/Hide L...
  3. I have a drawing I want to plot to 1/8" Scale. I'm drawing at 1:1 scale and When zooming in to draw my line weights look accurate, however when I zoom out to view my whole drawing lines are to thick/blotchy and shapes are distorted. I've played with plot styles, dimension styles and my line weights...
  4. Hello helpful people. I'm having a problem I haven't encountered before. Every line I draw, no matter what layer I make current is showing up as a thick red line. It doesn't matter if the layer that is current is green or what the lineweight is. I bound an xref to my drawing; I don't know if...
  5. Jerry Koler
    Line Thickness
    I am using Autocad 2007. Cannot get the all lines and text to plot correctly, some are correct but some are way too thick as though they are potting by thickness and not color. I changed the color and they still plot thick. In checking the properties box they all seem to be the same. Tried blocking...
