Showing results for tags 'layout tabs'.
    • layout tabs ×
Found 7 results
  1. If only QSelect weren't lying when it gives the option to search "Entire Drawing." As the title says, I'd like to be able to grab all instances of an object (typically a block) across multiple layout tabs in paper space (if it were in model, this wouldn't be a problem). The end goal being to cha...
  2. I want to change attribute text in title blocks, calling the block by the block name, not selecting the block, looping thru all the layout tabs. The title block will have the same name on each layout. My titleblock is named TITLEBLOCK30x42, with 2 attributes SHEET-TITLE and SHEET-DESCRIPTION....
  3. Hi, I have a few dwg shop drawings with some 80+ layout in them. I need to plot some of them but I have access to only the tabs that are shown on the screen. Is there a way to plot say the 40th sheet/tab back to the 1st tab using for example shift+home after selecting the 40th tab. I think i...
  4. Hello, Firstly,Sorry for my English and I admit I'm addicted to making enhancements in CAD drawing I'm looking for quiet simple way to copy current layout and move it to end using only some commands. I know "Move or Copy..." dialog box method but I need to do exactly the same thing using com...
  5. Hello all, I've just joined this forum and looking forward to it's friendly community! I have a problem for now, can't solve one thing - it's just somehow Xref drawing doesn't appear in layout/sheet space. Sorry for my English. If it's clear, does anyone knows how to make it? I'd appreciat...
  6. hcostanzo
    Color of layout tabs
    Does anyone know what controls the color of the layout tab that you are in? Mine is so dark I can't read what it says. When I'm in model space the text is white on a black background (which is easy to read) but all other tab names are black text on a grey backgroud. I've changed the color...
  7. Hi, I am looking for tools be it tips and tricks or lisp that can help and make the most of layout tabs especially when I have many layout tabs in my dwg. Thanks for your helps and directions. Regards, Nicolas
