Showing results for tags 'layer states'.
    • layer states ×
Found 5 results
  1. I have a drawing with multiple Viewports using different Layer States. How do I know which Layer State is being used in each Viewport.
  2. I know this showed up in the RSS Feeds forum, but it may be of some interest to someone who may not see that. AutoCAD for Mac 2015 and AutoCAD for Mac LT 2015 were announced and released yesterday (14 Oct 2014). You can find a brief summary of the new features and additional links here.
  3. I'm working with AutoCAD Architecture 2011 and working in the xref. I have my layer states set up, no problem. However, I have a layer that still shows up in all states even tho it is not saved in the layer states. If i click on it, it shows as off. It is a block, I have it on the ByLayer and the co...
  4. Hi, I am having problems with my Layer Manager. Say I make a new layer and then freeze it or turn off in certain layer states, and save changes. The layer does not respond to this- it stays visible when I return to the drawing, and then when I go back to the Layer Manager it is no longer off as I...
  5. Recently i changed the layer color for a drawing in AutoCAD. However, each time i would use one of my layer states, the layer would change to the previous color. SOLUTION: Since i use layer states quite frequently, i keep a drawing with them saved in a prototype directory. All i had to do to...
