Showing results for tags 'layer rename'.
    • layer rename ×
  1. *Disclaimer* I'm not sure where this code came from, it's probably hashed together from several forum posts. I'm working on revising this layer renamer that didn't quite work. I've got the dialog box setup and working fine. I've got the layer renaming functions setup and working fine. The pro...
