Showing results for tags 'layer properties'.
Layer does not appear in viewport and plotter.
farycj posted a topic in AutoCAD Drawing Management & Output
Hi, I try to plot my drawings in this new template that i created - with all those new layer. I have compared it with my other drawings, the layer properties is pretty much the same however for this drawing, some of my layer are not visible in the viewport and missing when i plot the view. A...- 7 replies
- viewport
- missing layers
Hi, I have a problem that I have many drawings which contain number of the same block which should be hide. Based on tips from another threads I came up the following solution which I don't know how to utilize. First -> I use lisp which create new layer, then blocks with the same name are m...
- 6 replies
- moving block
- layer properties
I've updated to 2015, and most of the changes aren't a big deal. However, the new version shows the layer properties window with a medium grey background. I find it visually difficult to tell what items are selected and to read the text. Does anyone know if it is possible to change this window...
Select either Doted line or full line of the same Layer in AUTOCAD?
tipu_sultane posted a topic in AutoCAD Beginners' Area
I got the CAD file and want to find the length of the line of specific layer. The image attached contain the red line one dotted and other straight and full. The dotted represent the existing and full & straight represent the new & Proposed. By using the select similar I got the...- 2 replies
- layer properties
- layer
