Showing results for tags 'layer names'.
    • layer names ×
Found 4 results
  1. Hi, I am trying to find a way to label points with its own layer name like the attached lisp commando. It does it with line/polylines. Also I am trying to find a way to do this with multiple points, therefore the rotation of the imported mtext does not need to be aligned. Coul...
  2. Dear folks, We all know that Revit has tagging capabilities and I know that AutoCAD can also do that with Lisp. Lets assume we have 5 different solid hatch each in different layers like: Layer Name - L1 Layer Name - L2 Layer Name - L3 Layer Name - L4 Layer Name - L5 I want to place...
  3. Hi, i export from arcGIS server shape files, then i import them with object data using drawing layer and "use data field for layer name". I get layers created by "codes". After that i use LAYTRANS to translate layers to my own created layers. So my question - is there any way to automatically inser...
  4. allie
    Layers dialog box
    When I open the layers dialog box my layer names are scrambled up and not in order like they once were. I have to hit the "Name" tab to get them back. I have tried re-setting it back to how it was but can't figure out how. When I opened an old file of the same drawing and the layers are in their ori...
