Showing results for tags 'layer control'.
Hello all, i have received one CAD drawing, in drawing, two plan is arrange one above another (two layer) in model. but when i switch it to layout, two window is there with both layer separately. how they did it ???
Change color in Model space ONLY?- big SNAFU happened!
Sbeth85 posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
I have a layer for boiserie that needs to be printed out in a dark brown, but I can barely decipher it in Model Space on the black background. So, I've been tending to change the layer color to light brown just so I can see it. Yesterday, I accidentally ordered 30 huge colored sheets with the wr...- 14 replies
- layer control
- color plotting
Hiding an object in a viewport on the same layer as others
Liltygar posted a topic in Mechanical & MDT
I am trying to hide a specific object that is a part of other layers. I do not want to hide other layers or have this line hidden in other view ports. Is there something that can be done? i have tried in the view port to hide object, and the object was hidden in my other view ports as well. Isol...- 5 replies
- object
- layer control
I have a simple drawing (very suitable since I am very much a newbie) with the object drawn on Layer 0 and the dimensions on another layer named (by way of novelty) Dimensions. When I sent this drawing to print I only get Layer 0 - no dimensions. In photoshop-type applications the process i...
Hey guys. I have a LISP I wrote this morning that asks for an insertion point, grabs the layer of the object, then draws a MLEADER on an associated layer. I have it working completely, except when a block is selected. Can anyone take a look at the code and help out? Thanks in advance! (defu...
- 14 replies
- lisp routines
- layer control
Layer control by viewport in paper space
Kari605 posted a topic in AutoCAD Drawing Management & Output
This only happens from time to time. I have a sheet set up with multiple viewports. I double click in one viewport, type LAYER, and the layer dialog appears but my viewport has changed. Anyone else have this problem and more importantly have a solution? Thanks. -
I recently started an internship with a company who makes radiators for power transformers. The first task they have given me is to clean up their plant layout file. The file currently has 125 layers in it due to machine blocks dragging in unwanted layers whenever they bought new machines. (presses,...
When I highlight any object in model space the layer control, color control or line type control does not change from the current layer status to the layer of the high lighted object if it is different. I am also not able through this layer control bar able to high light an object and use the fly ou...
- 3 replies
- layer control
- color control
Newbie here i have been using this forum frequently as of late and had a question i was hoping you could help me with. I am building a program in visual basic to select certain layers and change their color to outline a certain path on a layer diagram. I need to program a clear button that s...
- 1 reply
- programming
- layer control
