Showing results for tags 'issuing drawings'.
  1. Hi, Could anyone help me out with this issue I have. I'd like to create a routine that would help me issue drawings, only I am only just learning autolisps so it is rather confusing. The process is just to much when done manually. The steps that I usually do are bind all xrefs, purge then save the drawing with an added revision number at the end for instance drawingname_P1.dwg to an issue folder. Then print of a pdf with the same extension. It would be great if someone could guide me through the process or has a lisp that we could use as a basis. I have one that seems to work but not exactly. thanks
