Showing results for tags 'inventor 2015'.
    • inventor 2015 ×
Found 9 results
  1. dusko
    Fillet problem
    Hello people! I have problem with fillet as you can see it on picture. Can't figure problem out. Do you have any idea why this is happening, since this is tenth (similar) part i have done. File is over 500KB so i can't upload it. Thank you!
  2. So i am in an inventor class and my teacher assigned the three drawings i attached below. 1.) How would i go about drawing this? There is no assigned thickness. I'm not sure what the height of the bottom pyramid shape is. I tried 1.4 at 45 degrees and that didn't work. 2.) My main problem he...
  3. Hello, 1) How can I convert a file to be applicable to be edited in inventor from auto cad? 2) I have an STL file which I have tried to use the mesh add on from inventor to convert it to an editable file with no luck. Anybody know how to convert an STL file to an editable file in inventor?...
  4. Ryan Lindsey
    Export Drawing Layer Properties
    I'm looking for a simple way to export layer settings from one drawing to another. I know that you can export styles by right-clicking them in the styles editor but when I get down to layers it will only let me do them one-by-one. Is there an easier way? Is there a way to export ALL styles as one...
  5. In my AD Inventor 2015 when I open the mirror function the pop-up window appears but I cant select any objects or mirror planes. It could be because I use Inventor multi-monitor (One for tutorial videos, the other for ADI) and when I click to pause the tutorial ADI is no longer the active window & t...
  6. Hi! I've been having a problem for quite awhile now with this model, its a chair with a 4mm plywood sheet wrapped around the base of the chair. The plywood sheet act as a backrest for the chair. I seem to lack knowledge of the operation to make it happen.
  7. Hello all, New to the cad forum...and new to inventor after taking a two year break. I am creating an equal angle frame member using the frame generator, everything seems to work as per usual. 1. I select insert frame, select my iso structural section, select the dimensions of the sectio...
  8. Hello there, I have a specific problem creating a flatt Pattern from an Sheet Metal Part. My question is: Is it possible by the nature of the material and geometry to create such an flat pattern? Notice the Sweep Path has an circular sector. If it is possible, how can I do that , since I'm a...
  9. Most large applications include a User's Manual in the download. I haven't been able to find one in Autodesk Inventor 2015. Is there one lurking on my hard drive?
