Showing results for tags 'inventor 2013'.
Hi, How can I rotate a Spur Gear as you can see on the picture. http://s3.postimg.org/wbwxx2soz/rotation.png Thank you
- 11 replies
- rotate
- inventor 2013
Cannot make converted standard to sheet metal part create a flat pattern
Viu posted a topic in Autodesk Inventor
Attached is a part I need to convert to a flat sheet metal pattern, but I have no idea of how to do this. sheetmetalpart.ipt -
Can Inventor tell me the machining time needed for my part?
zmarcoz posted a topic in Autodesk Inventor
I read Wikipedia. It mentions machinability of different material. Assume I have a part that need to put into a CNC machine, base on the table of "Cutting speeds for various materials using a plain high speed steel cutter" http://en.wikipedia.org/wiki/Speeds_and_feeds . I should be able to cal... -
Can inventor highlight all holes/tapholes with the same features in an assembly?
For example, highlight all M6 tap holes in a assembly? Thanks -
I haven't used Inventor in about 4 years, and I tried to create a project in Inventor using the 2013 version, but once I created a project file a bunch of the original settings got messed up. I now can't open a drawing, assembly, or presentation from the home window that pops up. I can only use the...
- 5 replies
- help me
- help wanted
I am trying to learn how to project geometry in inventor 2013 to cut down how much work I am putting into my project and getting frustrated with it. The issue I am having is that when I project geometry from one side to another side it projects it to the same side instead of projecting it to the si...
I'm using Inventor Publisher to create .mp4 videos. I'm relatively new to publisher, but it all seems very straight forward. The trouble I'm having is, in the videos everything seems to "flash" during set snapshots. In particular the parts list is rendered almost illegible. By "flash" I mean th...
Hello, another Showcase question. Is there a way to use alternate lineups to show different variations of a product? I need to show different sizes of the same accessory within the same document. Any help as to how I could do this would be greatly appreciated. Lewis.
- 2 replies
- showcase 2013
- inventor 2013
Hello all, I am trying setup a default part list for my company in Inventor, where I am stuck at is I wish to lock the width of the columns so on all our drawings the part list is the same width, I have assigned each column its own width and when I bring it in to the drawing it's the correct siz...
i have lofted two different triangles made by using line. they lofted fine but it is see through, how do i make it opaque? i use inventor 2013
- 4 replies
- loft
- inventor 2013
