Showing results for tags 'inventor 2012'.
    • inventor 2012 ×
  1. George Winton
    custom colors in Inventor
    There are many color choices in IV when creating a part. Too many for me. How can I create a custom color pallet of say just 10 colors?
  2. Is it possibel to link all lengths to unit QTY in bom, and partlist, i know frame Generator is using G_L for length, i've tried using it in other parts but no result. also when doing multi body parts, how is it possibel to use parameter in assembly parts. i'm interrested in this because i d...
  3. I worked with a 3D model in AutoCAD 2012 and then I wanted to add some variable fillets so I saved the part to be filleted as a block and the opened it in Inventor 2012 using Open > Import DWG. I added the fillets and then I used the "Export to DWG" command. I inserted the part in AutoCAD again usin...
