Showing results for tags 'internal gear'.
    • internal gear ×
  1. I use Autodesk Inventor 2016 (I'm trying to draw a Wankel engine) I have a (blue) large internal gear that revolves around a stationary (green) small normal gear. It works fine and the teeth mesh. I also created a (red) square block with a hole in it that has the same diameter as the outer diamete...
  2. Hi Folks, Got an issue with Planetary (internal) gears and dynamic simulation. basically, i have one sun, one planet and one carrier -internal gear. All are designed to move freely. I can get the DS to work fine, providing I dont contstrain the planar top of the sun to anything. This mean...
