Showing results for tags 'internal error'.
Not Able to Copy Paste any of the objects in drawings
Ashishs posted a topic in AutoCAD Drawing Management & Output
Hi, I am not able to Copy Paste any of the objects in attached drawing. new block.dwg Errors as follows- *Warning* Multiply owned object, handle "27" pasteblock Duplicate definition of block _ArchTick ignored. INTERNAL ERROR: !dbdxfout.cpp@874: eNotThatKindOfClass Tried dxfout com...- 15 replies
- internal error
- handle
VVC: internal error - WC:Internal error Autocad 2015
Grant posted a topic in AutoLISP, Visual LISP & DCL
Found this a problem with Acad 2015 - if you get this error go into your code and look for 'mapcar' then within that look for 'command' and change to 'command-s' (if plst (progn (mapcar '(lambda (X) ;turn layer on (if (> (cadr X) 0) (command-s "._-LAYER" "_ON" (car...- 1 reply
- acad 2015 error
- internal error
