Showing results for tags 'inserting blocks'.
    • inserting blocks ×
  1. Does anyone know how to update a block already present in a drawing with a block pasted from another drawing. I cannot use insert block with a file named the same as the block in the current drawing because the pasted block (of the same name) contains a visibility parameter that if I explode bef...
  2. I have a master drawing from which I create smaller, detail-view type drawings. When I copy from the master to create the smaller drawing, several of the blocks (and it's always the same ones) turn invisible. This means, with every new drawing I create, I have to re-insert these blocks to make the...
  3. Hey all, I have a quick question. I apologize if this has already been asked, but I can not find it myself. I have searched other spots, but its hard if the thread does not specifically deal with your question. My problem is, we have a LISP routine at my company. After you get all of the informa...
