Showing results for tags 'insert block'.
I need a complicated lisp for take information to attributes and choose blocks in cad file. So, I am working about Building Automation Systems, I am preparing "point list" and " connection diagram" for a project. My manager wants a lisp from me for choose blocks and insert data from excel point lis...
- 2 replies
- insert block attributes
- insert block
Hi all, Here's a routine originally wrote by LeeMac. I wanted to delete the previously inserted blocks after it's done updating them. Thanks in advance. I'll wrote where the problem lies in my code. (defun c:BK_Update_InsertAll_Redefine_ATTSYNCAll ( / dir doc extn spc ) (setq...
Hi, I need to run a scrit on multiple files and I would like it To chose wich SCR to run bas on the begining of the Name of the DWG File. In this case i have file with 2436, 3648 etc... and my scr would need to run the 2436INS.SCR on the 2436 ans same thing with the 3648 etc... I have try usi...
- 7 replies
- lisp
- insert block
Insert New RevBlock above existing RevBlock in Layout tabs
Fett2oo5 posted a topic in AutoLISP, Visual LISP & DCL
We are looking for a way to revise multiple layout tabs (single .dwg file) at one time. We design our product in 2D in one .dwg file. We use the layout tabs for multiple views of the objects that are in modelspace, (each layout tab has the project titleblock on it, but each layout tab has its o...- 18 replies
- layout tab
- insert block
Hi all, Ok, so I am a newbie here (and to AutoCAD). I did attend a beginners 4-day course a few months ago (before I got CAD in work) and I've forgotten half of it. I started on a new template - changed 'units' to architectural as this project needs to be measured in feet & inches. I started...
- 32 replies
- scale
- insert block
Hello, I know this is a user error on my part, Bu I cannot figure this out for the life of me. My company have a set of blocks in a .dwg file on its own - let's say they are circles with radii that vary by 10'. In another drawing I want to divide a polyline using a one of these circle blocks...
- 2 replies
- scale
- insert block
insert block and make the force autocad updating TAGS
rodrigo_sjc_sp posted a topic in AutoLISP, Visual LISP & DCL
How to insert AUTOCAD block and make the force autocad updating TAGS?? I use this command (command "insert" (strcat "*"blockwithPath) (getpoint "\nSelect insertion point: ") "1" "0" "1") -
Does anyone know how to update a block already present in a drawing with a block pasted from another drawing. I cannot use insert block with a file named the same as the block in the current drawing because the pasted block (of the same name) contains a visibility parameter that if I explode bef...
- 3 replies
- overide block
- inserting blocks
How can I get the outline of "Insert entity" ?
kenjung0730 posted a topic in AutoLISP, Visual LISP & DCL
Hi, all: I have a trouble with dealing Insert entity. I got a "Block" named "AA", which have one "lwpolyline" entities inside. And then I insert it with "scaling & rotating". The problem is, if I want to get the current outline of "Insert". My process is as below. 1. get "Block entity... -
Im having some troubles inserting a block into a line. See image. The block on the left inserts into the line and has attachment points (AutoCAD P&ID Provided) the block on the right i created. Im unable to get it to insert within the line without manually breaking the line after insertion, the resu...
- 11 replies
- insert block
- blocks
Updating block references.
SAFeSTeR posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Ok so here's the situation... I have approx 150 files all with multiple layouts, each layout containing a legend block that needs updating. I edited the existing block and used WBLOCK to save it out ready for use in the other drawings. When I try to insert it into another drawing it gives me...
